Ga door naar hoofdinhoud
Released June 2017, identified by model number: SM-J530F
Reboot wont work and safe mode too
Hi guys im new on this forum I have a problem with my phones Samsung j5 2017 just died and wont start…
tried home button volume key up and power nothing happens, but if I hold the volume key down and power button I get one vibration and wont start but if I hold it for more longer I get one vibrate every 10 sec or so . Can someone help me or what should I do
Is dit een goede vraag?
2 opmerkingen:
hello my phone is samsung j5 2017 it's kernel just crushed so is there any way i can fix the problem bcz the phone is off also
door
@davebrown76190 Charge the phone fully, enter recover or donload mode flash stock firmware using odin if in download mode. perform factory reset if can
door
Voeg een opmerking toe
1 Antwoord
Ensure the phone is connected to a working charger and leave it for at least an hour. Try different charging cables and adapters.
Check for visible physical or water damage that could affect functionality.
If the battery is removable, take it out, wait a few minutes, and then reinsert it.
With the phone off, press and hold the Volume Up, Home, and Power buttons together to see if you can enter Recovery Mode.
If the above steps don’t work, it’s likely a hardware issue.
Was dit antwoord nuttig?
Voeg je antwoord toe
Yll Kastrati zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 83
