MBP Not Detecting Battery
After replacing the faulty speakers of my MBP in-line with the iFixit guide, the device stopped detecting the battery. At login, the battery icon shows 0% for a couple of seconds, then shows an “X” icon. Also, System Report does not identify the battery.
I have tried removing and re-connecting the battery, and both SMC and NVRAM.PRAM were reset, but to no avail. The laptop works fine with the power cord, sometimes slightly laggy.
All was working fine prior to the speakers replacement.
Any help would be greatly appreciated. Thank you.
Is dit een goede vraag?
4 opmerkingen
Given the age of your system I think it just was its time.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
That should nail things down.
door Dan
After answering about what @danj is asking bout - Did you happen to use a plastic tool to lift up on the battery or something metal? I ask because we see this happen quite often if a few of the battery pins are shorted out.
door Joseph Hughes
@danj For some odd reason, CoconutBattery quits unexpectedly.
door julianbugejacoster
@joesipaq I did use an iFixit plastic tool to lift all connections during the whole process.
