Ga door naar hoofdinhoud
A high end laptop, made from Aluminum and Carbon fibre chassis, that Dell manufactured in 2018.
10 Vragen Bekijk alle
Electrical noise coming from the center of the laptop
I’m hearing an electrical noise coming from the center of my laptop. It sounds like voltage jumping over a small gap.
It’s not related to the fans.
this is the noise. Ignore the birds chirping in the background:
https://drive.google.com/file/d/1LCkWJ8S...
The noise is coming from this area of the laptop:
Is this normal behavior, or should i have this looked at?
Could this be resolved by unplugging and replugging certain connectors?
Is dit een goede vraag?
1 Opmerking:
Either way it needs a thorough clean. Download the service manual PDF www.dell.com/support/home/en-uk/product-support/product/xps-15-9570-laptop/docs carefully clean it. May be some short circuit is happening, Clean it well..
door
Voeg een opmerking toe
1 Antwoord
Not sure I heard exactly the sound you’re getting at. I had a problem back in the day which had to do with speed-step. Disabling that in the bios helped. It was a sort of electric sound from the processor. Highly annoying. can’t say if it’s the same sound you’re experiencing.
Was dit antwoord nuttig?
Voeg je antwoord toe
Bert Verhelst zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 13
Altijd: 302
