Ga door naar hoofdinhoud
Repair information for Sharp televisions.
105 Vragen Bekijk alle
No picture but I have sound
Went to bed last night tv was fine, got up this morning tv picture is black but I have perfect sound?
Is dit een goede vraag?
Score 5
1 Opmerking
Buen día, tengo el mismo problema. LCD MODEL 50BL2EA
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
@sheffwife we need your TV's complete model number. You also should let us know what you have already checked (Tried all different Video input sources etc.) You also want to try to unplug the TV and unplug all accessories connected to it. Then hold the power button depressed for something like a minute or two. After that plug one video source, preferably local like game console, DVD/BR player etc. and see if you now get video. If not the check in a darkened room, shine a flashlight at an angle against the TV screen (TV must be on and you have to have sounds etc.). If you can make out shapes, silhouettes etc., then you know that this is a backlight issues. If not then there is the possibility that this is a main board, power board, T-con board or even the display panel. We would need to see your boards etc. to make any kind of further repair suggestion.
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Model LC-4OUG7252K
Tried to reset, but now sound gone as well!
Any further help/advice would be good?
Thanks
door
@Paul Casey How did you attempt to reset? What did you check before?
door
Led light could be blown and shorting other led off or t-con board may be damaged in an LCD TV
the power light is on, the picture is dark
Voeg je antwoord toe
Pamelapreston24 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 134
Altijd: 11,894
