Ga door naar hoofdinhoud
The EOS 5D is a 12.8-megapixel digital single-lens reflex (DSLR) camera body produced by Canon. Released Q4 2005.
Hot shoe broke and screws broke in camera won’t unscrew out
How can I get the screws out with no head they are loose but will not come out
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
If they have no head you can try to shove a hard flathead to make a grove and screw them out, you can try with tweezers or worst case scenario, drill them out.
To remove stripped screws: If you can get at the screw heads try to grab a long-nose pliers and squash the screw head, then you can try to use a flathead screwdriver or by turning the pliers, if that you don’t have those tools you can try with the normal screwdriver and a rubberband in between.
Japanese cameras use JIS/JCIS (Japanese Camera Industrial Screws) screws not philips.
Was dit antwoord nuttig?
Voeg je antwoord toe
Martika Wallace zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 527
