Ga door naar hoofdinhoud
Uitgebracht in 2013, te herkennen aan modelnummer PS 5530. All-in-one printer, scanner en kopieerapparaat. Beschikt ook over web- en draadloze functies.
Power AC Adapter search
Hello all…Please can someone tell me where do i buy the AC power Adapter that is shown in your repair videos for the HP 5530-e all in one showing that the Ac Adapter can be removed from under the left hand side of the printer casing , and to change when it’s not working ?..look forward to your replies .
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi @ericthevike66,
Not sure if it is the same for a HP Envy 5530e but looking at this image in the ifixit HP ENVY 5530 voeding vervangen guide, the model number for the power supply is A9T80-60008.
Afbeelding
(click on image to enlarge for better viewing)
When searching online using the model number only, there are results for suppliers. Here is just one to give you an idea of the cost.
If the model number of the power supply is different for your particular model then search online using its’ model number to hopefully find suppliers that suit you.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hello Jayeff…thanking you so much..have used the info to order my Power AC..Thanks a million.
door
Voeg je antwoord toe
Eric Fielding zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 274
