When screen has a black area, or goes black it turns a bright green
All the black area on screen turns a bright green. Help please.
Update (09/24/2020)
Update (09/20/2020)
I've obviously indicated the wrong model number, these instructions don't match my machine, it's an 17 inch mid 2010, non removable battery, MacBook pro 6,1, intel core i7, 2.66 GHz. Serial # C2QF300CDDKO, could you please send a link to instructions to check the display cable on my machine. Thanks.
Update (09/20/2020)
The green appears when I open the screen back past about 90 degrees and goes when I almost close the screen.
Is dit een goede vraag?
Can you please try to explain further? I had quite a hard time trying to understand what is happening...
door amatsuda
So if you have something on your screen that's supposed to be black it's instead a very bright green?
door amatsuda
How about posting a few pics so we can see what you are seeing! Voeg afbeeldingen toe aan een bestaande vraag
door Dan
That's right, I did find a posting on this problem from back in 2012/13. and when I connect to an external monitor the problem is not on the external, but is still on the MacBook screen. Why does my screen display black as green?
door Michael Itchins
@mike1946 what happens when you attach an external monitor? Do you get the same appearances??
door oldturkey03
5 commentaren meer tonen
