Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Budgetlaptop uitgebracht door Hewlett-Packard in 2015.
Computer says no boot device found
im having a similar problem with my hp stream 11. the internal operating system was erased. now when i turn it on it says no boot device, i made the usb installer as suggested but when i plug it into my labtops usb still says not bootable disk enter bootable disk and press any key. i changed the bios setting followed the YouTube videos close as possible please what am i doing wrong cause rt now its and expensive paper weight.
Is dit een goede vraag?
Score 2
2 opmerkingen
Hi,
Did you make the USB "bootable" when you created the installer USB?
Did you press Esc quickly followed by F9 when starting the laptop to select the USB as the first boot option, not quite sure if this is what you meant when you said that you changed the BIOS setting presumably the boot order?
door Deel
I'm running into the same situation, but my model is 11-r015wm. I used Rufus to flash a Windows 10 iso to a flash drive. I changed the bios settings to allow for legacy booting, and tried booting to the flash drive both with this turned on and off, and specifically using the bios boot menu to select a device to boot from. The bios doesn't see any flash drive I use. Idk if the issue is my flash drives are usb 3.0 and the only usb 2.0 I have is too small for a Windows 10 iso. I tried using a micro sd card but the laptop didn't recognize it either.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi @Christian Sirolli
Don't know the laptop and the user guide doesn't show the BIOS menus but since the USB is not being detected at all in BIOS, check under the Advanced tab menu for Integrated Peripherals or Onboard devices or something similar to see if there is a USB Controller enable/disable option.
Some BIOS allowed for the USB to be turned off as a security measure
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Sadly, there is no advanced tab. I've searched through each section and it is super basic. Downsides of having a budget laptop
door Deel
@Christian Sirolli
Did you create the Windows ISO USB with UEFI support?
door Deel
Voeg je antwoord toe
jayr5369 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 23
Altijd: 1,116
