Ga door naar hoofdinhoud
The Razer Blade (2018) is a 15.6-inch gaming laptop released in May 2018.
20 Vragen Bekijk alle
Where can I purchase a replacement fan
one of my fans is making a grinding noise. I see there is a guide on here how to replace it but where can i get the fans.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
https://www.amazon.com/Cooling-GTX1060-R...
https://www.aliexpress.com/i/33012273436...
Here are some links. Before you proceed though, you should make sure it’s not just built-up dust blocking the fan.
It will potentially save you time, money and effort.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for this. I will double check the dust but i have cleaned out using air.
door
No problem Alex :). It could also be hitting a wire, hence the noise. Make sure everything is properly into place and that wires don't overlap where they don't need to.
door
Voeg je antwoord toe
Alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 4,239
