Ga door naar hoofdinhoud
Panasonic TV no screen
Hi
I have a Panasonic tx-48cx350 LCD TV that has stopped working. When I switch it on the Red LED comes on and the screen flashes a white flash maybe a couple of inches from the bottom of the tv but no picture. However sound does work. The last few months there has been a small area on the top right of the tv that goes dull for a few moments intermittently.
On Powerup the LED flashes 4 times pauses then flashes 7 times, on the 4th flash of the second sequence that’s when the screen gives a white flash around the location of the TCON board.
Hope you can help.
Regards
DJ
Update (05/27/2020)
Hi
Thanks for the reply
Disconnected the LVDS cable, TV does exactly the same thing.
Regards
DJ
Afbeelding
Afbeelding
Afbeelding
Is dit een goede vraag?
2 opmerkingen
No picture sound only
door
@balanbal
Please confirm the model number of your TV?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
@djbsystems the 4 blink code is known as power SOS. Try this. Disconnect the LVDS cable and turn your TV on. If it turns on then the issue is with the panel. If it does not then the issue is most commonly with the power board. Post some good pictures of your boards with your QUESTION so that we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hi @djbsystems ,
Saw on the images that you posted that it is a Vestel 17IPS20 power board.
This link may be of some help in finding the problem.
door
Voeg je antwoord toe
Dougie James zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 1,371
