Ga door naar hoofdinhoud
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Vragen Bekijk alle
Taking long time to start
Having to hold key a quite awhile to start. Acting like it was t getting fuel. Replaced fuel filter and put new spark plugs. Didn’t fix so put on computer. Threw the code for cam shaft sensor. Replaced today and still is the same. Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I had this problem a while ago and it ended up that my alternator was dying after I got it replaced the problem went away another way to check if its the alternator as if you turn on the indoor light when the engine is running and if it flickers that is a common symptom
Was dit antwoord nuttig?
Voeg je antwoord toe
Dawnn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 46
