Ga door naar hoofdinhoud
A redesigned Pathfinder went on sale in late October 2012 as a 2013 model. Just like the second generation Pathfinder, it once again moved away from a body-on-frame, truck-based SUV and adopted a unibody design.
12 Vragen Bekijk alle
2016 pathfinder sv smokes on start up
2016 pathfinder briefly smokes on start up and is consuming oil 76k no warning lights some loose sludge in valve cover on front
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
what colour smoke is it? any car on start up will show a little smoke, if its thin white smoke its just condensation and nothing to worry about. if its a thicker blue then it might explain the oil consumption as this could be related to worn piston rings, valve seals, intake manifold gaskets and clogged oil drains. I would start by replacing the valve cover gasket as its a relatively easy job for anyone to do and usually the most common to go first.
Was dit antwoord nuttig?
Voeg je antwoord toe
Shawn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 895
