Ga door naar hoofdinhoud
The Dell Chromebook 11-3120 is an affordable, lightweight laptop that is most commonly used in professional and educational settings.
7 Vragen Bekijk alle
Chromebook not powering down when closing lid
CB will not power down when you close the top lid. Or go in to sleep mode.
Is dit een goede vraag?
Score 1
6 opmerkingen
can you give me more info on what happens
door
does the screen stay on?
door
yes, I found the problem. the magnet on the backside of the bevel came out of its bracket.
door
@Justin Jordan yup just as I thought if the Chromebook does not read the magenet it does not go to sleep. is that all?
door
yes, thanks.
door
1 commentaar meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
solved magenet came off bracket
Was dit antwoord nuttig?
1 Opmerking:
Where is the magnet located? I’m troubleshooting a CB right now that will not sleep when the lid is closed… The option to sleep when the lid is closed is enabled.
door
Het nuttigste antwoord
It is built into the bezel.
Score 1
Voeg je antwoord toe
Justin Jordan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 34
Altijd: 3,150
