Ga door naar hoofdinhoud
The HP Compaq 6730b is the "business" edition of the 6730 laptop line released by HP.
Why doesnt my computer turn off
why does my computer not turn off ?
Is dit een goede vraag?
1 Opmerking:
Have you tried holding the power button for 5 or more seconds?
door
Voeg een opmerking toe
2 Antwoorden
The following command will completely shut down your computer in Windows:
Right click Start icon and select Command Prompt
Type or copy/paste the following in that window:
C:\Windows\System32\shutdown.exe /s /t 0
After your computer has shut off, restart it again and then try testing shutting down as normal.  If computer still won't shut down, please post what operating system the computer uses and your method for shutting the computer down.
Was dit antwoord nuttig?
use forced turn off i.e
1-hold power button for more than 5 seconds
2- use command prompt shutdown
3- you will be forced to remove the battery if the laptop is completely unable to shut.
Voeg je antwoord toe
Ray Hagen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 299
