Ga door naar hoofdinhoud
Device name is Jensen 3 speed stereo turntable. Model is JTA-230.
9 Vragen Bekijk alle
Why won’t regular headphones and earbuds fit in the headphone jack
We recently purchased this model turntable specifically because it has the built-in headphone jack. However, regular headphones/earbuds won’t fit the jack. Do I need to buy an adapter or return it?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@sharpmom teh Jensen JTA-230 uses a 3.5mm headphone jack which is pretty much standard for headphones. The question now is what size is the connector on your headphones/earbuds. Measure the diameter of your connector and let us know what it is. Or post some images with a measuring tape next to it so we can see what you are dealing with. It is not the JTA that is unusual. If nothing else maybe you have a make and model for your headphones/earbuds Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 1
Buy an adapter. That is the first thing I would try.
Voeg je antwoord toe
Christine Sharp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 90
