Ga door naar hoofdinhoud
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 Vragen Bekijk alle
Replacement digitiser - home button not working
I’ve just replaced a friends digitizer on iPad 5, and the home button doesn’t work. I tried checking the connections and all seem fine. Any ideas please?
Is dit een goede vraag?
1 Opmerking
Crikey I might need it - thanks for your help!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Did you use an iPad Air digitizer with pre-installed home button? While the digitizer works on both Air and 5th gen, home button is not interchangeable as they use different protocols.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you - that’s interesting - it did say iPad Air / iPad 5 so probably. The previous home button was damaged by the glass, so I assume a new home button is required? I’m worried if I try to take the digitizer off again, it’ll damage the new one though?
door
@jg0254 That explains it, you need to buy a new iPad 5 home button, you have no choice but to take the digitizer off again :(
Do it with care to not break the glass, good luck.
door
Voeg je antwoord toe
Jake zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 83
