Ga door naar hoofdinhoud
4.0 megapixel point and shoot digital camera by Canon.
5 Vragen Bekijk alle
Constant Memory Card Error
I keep getting “Memory Card Error” no matter how many cards I try. Can it be fixed? Thanks
Is dit een goede vraag?
Score 2
1 Opmerking
Are you able format it?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you are formating the cards on PC, are you using FAT32 or exFAT (or NTFS?)? You should format your card to FAT32.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thank you so much for your help. I was formatting at the incorrect settings. Thanks again. Best news I have received in a long, long time.
Irving E. Carlson
Owner
Carlson Studios
door
door
Can someone please explain "formatting a card on PC"? I just got a new memory card from Amazon and "memory Card Error" appears with old and this new card"Tab on side is in up position. Sheila, Senior Citizen. Thank you.
door
Thank you for share with us.
door
Voeg je antwoord toe
Irving Carlson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 315
