Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
20 Vragen Bekijk alle
5s and se the same
I have a iPhone se in poor condition with a broken screen. I also have a 5s in perfect condition that is iCloud locked.
What are my options to get one good phone. Can I transfer screen from 5s to the se, are they the same.
what do I need to take from se to put in 5s to stop iCloud lock, the logic board and home button?
Update (04/23/2019)
What about getting past the icloud lock on the 5s, anyway round it
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Iphone 5S is iCloud locked so you can not use its logic board or any part which is associated with imei number. You can use battery, body cover if size are same and display. But for Display make sure screw position alignment are same for both screen otherwise it will not work. Better to use both iPhone use iPhone carrier unlock code for iPhone 5s.
Was dit antwoord nuttig?
1 Opmerking:
Actually no, the battery is different between the SE and 5S, the only thing you can really use is the screen as they have the same connector. The battery and charging port have different connectors. Hope this helps.
door
If the 5S is locked and you want to restore the SE the one thing you CAN do is use the 5S’s screen on it. But the battery and charging port are different between the two models, if it’s just the screen your mainly looking for then your in luck. If it’s anything else major I don’t think anything else will work, that’s just from my experience, hope that helps.
If the screen is OEM, it will be pretty much fully compatible with the SE.
Voeg je antwoord toe
Aidan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 100
