Ga door naar hoofdinhoud
De M331 Silent Plus is een draadloze muis die in november 2016 door Logitech werd uitgebracht. De muis maakt verbinding via een USB-ontvanger en wordt gevoed door een enkele AA-batterij.
How do you open the mouse
Like the questions says.. My scroll wheel has come loose
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try following this guide to open up your mouse.
Was dit antwoord nuttig?
Score 19
5 opmerkingen:
Tks! M280 is same model.
door
Thanks.. a very useful guide..
door
Thanks for the guide, been looking for some time, and finally found it. Will try out the steps over the weekend.
door
Is it possible to remove the scrolling wheel spring? It's so noisy and beat the "silent plus" branding. I did this to all my previous logitech mice but seeing the photos above, it seems that there's no "metal" spring but a black plastic spring instead. Can you confirm? Thanks!
door
Thanks man
my left click now worked again, just clean it use contact cleaner.
door
in the answer provided by @arthurshi , I want to add three points:
In the picture, 4 notches were already highlighted with blue circles, but these 4 do not get locked. There are 3 more notches, in green, which gets locked when mouse is closed.
Afbeelding
1) There is a hole provided to insert a pin/screw driver, in green down arrow, & gently press the lever to the left, 1st yellow direction.
With this the lower portion of mouse will get detached.
2) then, we have to genlty slide the lower case to forward, 2nd yellow direction. For some reason this direction was wrongly mentioned in original answer.
3) Reverse process should be followed to lock the top two notches while assembling the mouse.
Score 2
2 opmerkingen:
Thanks for the guide bro, been looking for some time, and finally found it..
door
ecd, thanks for the addendum instructions
door
Voeg je antwoord toe
bwinter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 9,174
