Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Kenmore Elite HE3 is een wasmachine van Kenmore. Hij is identiek aan de Whirlpool Duet.
Washer says control locked
How do I unlock the controls?
Is dit een goede vraag?
Score 16
12 opmerkingen
Ken, great that mayer's solution worked for you :-) all you have left to do is to accept the answer as a solution. This way we all know in the future what to look for.
door Deel
Thanks Holly! :)
door Deel
It worked for me just now, too! Thanks a ton!! 12/15/2015
door Deel
Yay! Drain/spin and start button worked for me as well! Thank you, you saved me a service call!
door Deel
Thanks "Loads"! Yeah!
door Deel
7 commentaren meer tonen
Voeg een opmerking toe
9 Antwoorden
Filteren op:
Gekozen oplossing
Try unplugging it for 5 minutes and then plugging back in.
Was dit antwoord nuttig?
Score 4
8 opmerkingen:
It worked, thank you. Ken
door Deel
Glad I could help
door Deel
It did work for me too, Thanks
door Deel
I cant find the unlock button on my kenmore front loading washer
door Deel
3 commentaren meer tonen
Het nuttigste antwoord
abumblebee1, the normal procedure is to hold down the "end of cycle signal" (drain/spin)button for 3 to 5 seconds. The only other thing I could see is that the control interface has failed and has a stuck or shortened keypad. Give it a try and let us know.
Score 13
23 opmerkingen:
Holding "Drain/Spin" button down worked for me.
John, July 2013
door Deel
Thank you so much! you guys are great!
door Deel
tony, thank you and welcome to ifixit ;-)
door Deel
Worked for me! Thank you.
door Deel
holding down the "end of cycle signal" button worked for me , thanks.
door Deel
18 commentaren meer tonen
The solution for my Kenmore Elite he3 was to press the Drain/Spin button "and" main Start (press & hold) buttons at the same time for 3 seconds.
Score 9
13 opmerkingen:
thanks holly martin it worked...
door Deel
Oh good! Glad to hear.
door Deel
worked for me also! Thanks Holly!
door Deel
Thanks, Holly! I bought a door switch from Sears, they said this required it, but I should have read the buttons on the machine! Now I have to beg to get the $80 back, but the machine is fine.
door Deel
Thank you Holly that worked for mine too. I just purchased this set used yesterday and this isn't so user friendly . Hope I don't confine to have problems
door Deel
Press drain/spin button and extended spin for 5 mins it will remove the control lock.
Score 4
This worked for me as a temporary fix. Next load I received a F2 error code. This is a drain pump error. Actually turned out to be a very easy fix also. Removed lower front access panel (3 screws). Removed two screws holding the pump in place (Large round, white plastic canister looking device directly in middle front with screw on cap). After removing the pump pull up and forward. Place a deep pan under the pump, unscrew the cap by hand. There will be a fair amount of water drain. My pump had coins, a pencil and a lot of lint blocking it. Removed all the material, replaced the cap, replaced the pump and front panel. Machine now working fine. Only took about 10 minutes and problem solved.
Score 1
2 opmerkingen:
Great tip, cleaning the pump worked for me!
Thanks!
door Deel
Just a note: The white 'box' with the big screw cap is actually the drainage waste collector and the drain pump is actually to the right of that. It's surprising that the manufacturerer did not provide a little door on the front to get to this waste collector which needs to be cleaned regularly.
door Deel
Hi @lorismith34859
Here's an image from the Kenmore 796.31433710 user manual that shows how to activate/deactivate the control lock feature.
Afbeelding
(click on image)
Score 1
1 Opmerking:
THANK YOU!!!!!!!!!!!!!🙏🙏🙏🙏🙏🙏🙏🙏🙏YOU FIXED IT!!!!!!! YOU ARE AWESOME!!!! I was hitting the wrong button! THANK YOU SO MUCH!!!! You’re the BEST! 🤗🤗🤗
door Deel
Thanks hold Drain and spin button for 3 seconds worked for me thanks to
Have pressed drain/spin button and start button together for 3 second, no help. For 5 seconds, no help. Have unplugged and waited five minutes, NO HELP.
3 opmerkingen:
@catieb same washer? You have a model number? Control lock shows or are there any other issues? What is going on with it?
door Deel
I have the same issue with model # 79631553610, control lock is on and I cant turn it off, rinse/spin button not working etc...
door Deel
Press and hold the control lock button for about 3 seconds and it will unlock I just did it worked like a charm
door Deel
Afbeelding
Afbeelding
My red kenmore elite washer has the start pause button and the power button. It will not unlock at all and my clothes are stuck in it. I tried the unplugging it for 5 minutes and if will not work and sadly my washer does NOT have a cancel button. I need help please I’m desperate
4 opmerkingen:
Hi @meldes ,
What is the model number of the washer?
door Deel
@jayeff I am not sure. Where would I find it. This washer was here when we moved in a little over a year ago so I’m not familiar with it
door Deel
@meldes
Maybe check at the back either top left or right side. If not unfortunately it will be inside the door jamb.
Different model have different ways to open the door so knowing the model number will help.
The user manual wasn't left there by any chance, as the model number would be in it?
door Deel
@jayeff
I didn’t see anything last time I was down there last night but I will check later in the morning.
door Deel
Voeg je antwoord toe
abumblebee1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 54
Altijd: 74,361
