Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
SD card won't work
So I recently got pokemon sun for my 2ds, and it said I need an SD card so I went to a store and got an SD card, but when I put it in it said that it had write protection, and guess what? I had the switch turned up! And I try almost everything, I turn it down and up a billion times, I take out the game and turn it in every different direction, and it works ONCE but the game was used so it had a save file, and I look up how to delete saves, and I try it again, but it didn’t work that time, so can someone help me please?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @heckrum ,
The Most Helpful Answer in this link may be of some help to you as well.
Sd Card Slot Bad
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Ibrahim vincent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 669
