Ga door naar hoofdinhoud
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Vragen Bekijk alle
Why is my MacBook Pro 2013 late 15" randomly turning off
Hello,
I have MacBook Pro 2013 late 15” with 16 GB DDR3 RAM, 500 GB SSD and GT750m GPU. I have macOS & Windows (BootCamp) on the system.
Lately, it started to randomly shutdown while on battery while running macOS. I made clean install but same problem is occurring. I think it is something with cooling on macOS side, because in BootCamp I can play games on battery or plugged in and it never shuts down.
I did reset the SMC and same thing happening in macOS side. Seems like don’t having charger plugged in cause fans on macOS speed slower or do other things.
I installed Mac fan control and turn all fans on maximum. It still shouted down. Any advice here? Mac is my main machine and if I can’t take it somewhere where there is no power outlet making it useless.
more idle temps
Is dit een goede vraag?
4 opmerkingen
Lets gather some deeper diagnostics here. Install CoconutBattery as well as TG Pro. Both will allow you to see deeper into your system. Take a snapshot of the main window of both and past them here for us to see Voeg afbeeldingen toe aan een bestaande vraag.
You do want to remove the MacFanControl app as you don't want it to conflict and confuse what we are looking at here.
door
added img that you asked. I'm running external 2k 27 inch display, and have hdd, sound card, and keyboard plugged in. plus mouse. and Mac is charging
door
What do you mean by an HDD Sound card? You have an external HDD drive and as well as a USB DAC unit? Or do you mean you just have an HD Sound card?
Also are you running the system with the display lid closed or open?
door
opened, I have external hdd(wd passport ultra) and sandblaster 5.1 omni sound card, and keyboard, but this doesn't matter cause it turns off without all this. I thought it matter because temps might be a little higher with all those peripherals.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Macs typically the log the reason for random shutdowns, especially hardware related ones, you can try following this guide to see if it gives any more insight: How to determine Mac shutdown causes
Was dit antwoord nuttig?
Score 1
7 opmerkingen:
@jonaharagon - I would have just used the Console app and copied off the last crash report posting a PDF file of it here for us to review Voeg afbeeldingen toe aan een bestaande vraag
door
error -128. so i suppose it's gpu in cpu. intel iris 5200. cause i can play under windows without problem and windows use only gt750m
door
What did the crash report tell you? Error -128 is very generic, how about posting it here so we can review it.
door
Uploaded crash
door
I think you only put it in your tray as I don't see a link to it here. Create a new answer and then follow this guide Adding images to an existing answer
door
2 commentaren meer tonen
Voeg je antwoord toe
Max zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 139
