Ga door naar hoofdinhoud
De Sony Cyber-shot DSC-W830 is een 20,1 megapixelcamera die is ontworpen voor het maken van foto's en video-opnamen tot 720p.
How to fix error C:13:01? re-insert memory card?
I have sony DSC-W380, then suddenly after using cannot open file. the image was C:13:01, re insert memory card. how to fix it?
Is dit een goede vraag?
Score 1
1 Opmerking:
I had the SAME PROBLEM! On the SAME CAMERA! I need to know this answer ASAP. I re inserted the memory card and that didn't work. I tried another card, that didn't work.
door
Voeg een opmerking toe
1 Antwoord
I had this error about five years ago in a  Cybershot camera.  The error seemed to be caused by a bad contact  between the camera and the memory stick.
I gave the camera's slot a blast  of compressed air, cleaned the contacts of Camera & Memory Card and inserted &removed the  memory card several times in quick succession.
And this solved the issue.
Was dit antwoord nuttig?
3 opmerkingen:
I already did but its the same, no changes. =(
door
If there is no important data on it, try to format it using PC/laptop
door
cannot also detect on PC/Laptop. yes it has important data.
door
Voeg je antwoord toe
Joefine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 4,381
