Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en Probleemoplossing-informatie voor de derde generatie Apple iPad met 4G, beschikbaar met 16, 32 of 64 GB opslagruimte. Uitgebracht in maart 2012. Geïdentificeerd door modelnummers A1430 (GSM, AT&T) of A1403 (CDMA, Verizon). Voor reparaties is het gebruik van warmte en voorzichtig wrikken vereist.
Replaced digitizer starting to fail
iPad3. Last year I replaced my digitizer/screen with a new iFixit digitizer. Now, the left edge of the digitizer is dead to touch. The dead zone started about 1/8” wide and has grown to about 1/4” wide. Meanwhile the right edge is doing the same thing, about 1/8” wide.
I keep it in a wraparound case and I noticed the left edge is starting to come unglued. Is this related? Can I fix this somehow, or do I need another digitizer?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @wolfharper ,
I suggest that you contact ifixit regarding the problem with the touchscreen “dead zones”. It never hurts to ask
According to their iPad 3/4 Screen Digitizer parts information, there is a lifetime warranty on their parts
Replace a scratched or cracked front glass screen digitizer panel. This part is compatible with a 3rd or 4th generation retina display model iPad. Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 2
Try re plugging the screen back in. If it doesn’t work, you will have to replace the digitizer again . Let me know results … thank you
1 Opmerking:
Yeah digitiser needs to be replaced. I always add b7000 glue on bottom left and clamp down for a while to avoid this problem of the glass getting pushed up via the cable.
door
Voeg je antwoord toe
Wolf Harper zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 332
