Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
half of my display wont recognize my touch
my iphone work good but it wont open becose the touch area on the unlock slide is not working
i opened the device after that for sevral times but i was unable to fix it
thancks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is probably the infamous "dead strip." or Apples response to planned obsolence. I havent found any real solutions that worked for me. Some have reported having success with rolling back to an older iOS version and custom editting their settings tab to include the touch sensitivity option. This sorta worked for me...but it only seemed to relocate the dead strip to another section of the screen. But you probsbly cant even try that if you cant unlock your phone. You most likely have no other option other than replacing the entire Front panel even though the problem is only thr digitizer.
Was dit antwoord nuttig?
Voeg je antwoord toe
offirbh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 816
