Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De originele Blackberry Bold smartphone, voorzien van diverse verbeteringen ten opzichte van oudere Blackberry-modellen.
bb thrown on wall doesnt boot
threw bb to wall cant boot no light nothing.
-keeping it plugged and putting battery in, removing waiting30secs and repeating procedure leads nowhere.
-keep escape pressed for safemode boot doesnt work
-keep mute button pressed 30secs doesnt work
mystery selfhealings
-keep 10 hours offline and repeat above doesnt work
next appreaoch keep 24hours ofline and repeat above
-no recognition of usb in computer link
-wahts broken ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Check your battery, make sure you have any kind of output. Make sure that your battery makes a connection with the proper contact of your phone. After that it is time to perform a teardown on your phone and see what is obvious broken/disconnected etc. But do start with the power to your device. Good Luck and let us know.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
nice idea but the usb doesnt recognise it. that does work usualy without battery, doesnt it>?
i suspect boot rom
door
THe battery is ok. If you ever have troubles wiht yours keep mute pressed 30-40 seconds
first plug in leave it plugged
pull batter wait 30 seconds
put in batter wait 10-20 seconds
keep mute top pressed for 30-40 seconds while on cahrger.
it should live again
turn device soft off while loading full
door
The reason why I always check the battery and contacts first is to make sure there is no shortcircuit to prevent the device from not being recognized when plugged in.
door
i see. The battery is ok. I exchanged batteries. So any idea waht could be broken > as i said the thing doesnt LED red, doesnt start no recognition as if the boot rom is damamged.
-is there a self healing possibility? leave it a day unplugged and it restarts? -read this a few times now
door
Voeg je antwoord toe
test zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 1,356
