Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De derde generatie smartwatch van Apple, met optionele mobiele connectiviteit, uitgebracht op 22 september 2017.
Water damaged Apple Watch
I went out for a run, took my watch off because it died and I put it in my pants pocket. I washed those pants and now the screen is cracked and has water damage. It will not turn on. I’ve tried everything. Is there any possibility that my watch could be fixed and if so what would it cost? It’s a Series 3 I believe.
Is dit een goede vraag?
Score 5
3 opmerkingen
My Apple Watch died while I was inside the Pool and now is full of water inside how would I fix this ?
door
Hi my Apple Watch died too but I washed my hands my screen was already cracked and it stopped there got soap and water on the display and if I’m super unlucky it will be in the battery or logic board too I want to repair it by myself but idk what is broken or what to do someone I need advise and some thoughts if it’s riviveable
door
Same thing happen to my Apple Watch. Did you have to replace everything or just a few different parts?
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
If you believe it has water damage, you must disassemble and clean it using at least 91% isopropyl alcohol, (you can use this Demontage van de Apple Watch Series 3 to do that) make sure to scrub everything with a toothbrush.
more details on water damage can be found here: Electronics Water Damage
It is a tough repair, but as long as you follow the instructions you should be fine.
Was dit antwoord nuttig?
Score 9
1 Opmerking:
I went to the beach and I didn’t lock my Apple Watch and now the brightness is red and I can barely see or know where things are, hoe can I fix it?
door
I was scuba diving and found a Apple Watch and I want to see if it can be fixed
Voeg je antwoord toe
Breniecia Camphor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 63
Altijd: 38,155
