Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Screen replacement home button wobble
I am having an issue with the home button wobbling/sliding/sticking after replacing the screen on an iPhone 6s. I read the question ‘iPhone 6S home button "sticking" after screen replacement’, and it similar, but also different. If I tighten the screws on the plate that holds the home button in place, it makes it such that the button won’t depress. So, I loosened the screws and bent it a little and the button will depress, but it wobbles/slides around a bit. Now, if I put the screen back together all the way and tighten the screws that are by the lightning port, then the button becomes too tight again and won’t depress. Is it possible that the opening for the home button in the screen is too small (just a tiny bit)? If so, should I/can I enlarge the hole?
Thanks,
Rob
Is dit een goede vraag?
4 opmerkingen
Hi Arthur,
What gasket? There is a thin 'used-to-be-sticky' film around the home button, almost in a square shape. But as far as what I think of when I see the word 'gasket', there isn't a raised rubber ring or anything. Unless it fell off somewhere.
door
That is the home button gasket. It sounds like it's still there. It provides ingress protection and also adheres the button assembly to the display assembly:
iPhone 6s and 6s Plus Home Button Gasket
door
Hmmm.. I think you're right that it is still there, but it does not adhere to the screen back anymore. Maybe I should just get a new one. That should fix the wobble if it can adhere to the back of the screen. Thanks Arthur!
door
Please update us if that solved it!
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Well I wish I could say that it was the gasket, but it wasn’t. Turns out that the replacement screen’s opening for the home button actually was a bit too small. So, using a little bit of sand paper, I was able to just barely enlarge the opening and smooth it out (I guess) enough so that the home button fit properly. I appreciate everyone’s help on this.
Rob
Was dit antwoord nuttig?
1 Opmerking:
Thanks for the update! This will help us troubleshoot in the future.
door
Het nuttigste antwoord
Hi Rob,
Is the gasket that is adhered to the home button loose?
The gasket provides ingress protection and also adheres the button assembly to the display assembly:
Replace a torn flexible gasket between the home button assembly and the display assembly in an iPhone 6s or iPhone 6s Plus. Afbeelding
Product
$5.99
Score 2
Voeg je antwoord toe
Rob Cordeau zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 345
