Ga door naar hoofdinhoud
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
20 Vragen Bekijk alle
Why wont my battery charge?
i have a Dell Inspiron 1545 that wont charge, i have bought a new battery and charger (i left this thing in storage for over a year) and after i turned it on after a long time i get a message saying “ plugged in,not charging , i have tested the battery and charger on a relatives laptop and it works fine, what could be my problem?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Seems like the issue. could be with power relay/controller. Since it doesn’t deliver any current to battery, then it is most likely a faulty battery connector or somewhere in-between relay and connector an open end. (Assuming from the fact that AC still delivers power and your laptop runs just fine on AC alone.)
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
i have been trying to search for a solution google and seen a big amount of people have the same problem( some cases go as back as 2006), so a problem with the plug of motherboard would be likely, i will see if i can pry the laptop open to examine for any visible damage.
door
Plug of battery, I hope, you mean?
door
Voeg je antwoord toe
Carlos Cervantes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 270
