Ga door naar hoofdinhoud
Het Bose 3-2-1 Home Entertainment System is een serie op dvd gebaseerde thuismedia-systemen in de Bose 2.1 home theater-lijn. Het Bose 3-2-1 Home Entertainment System werd tussen 2001 en 2006 verkocht en was verkrijgbaar in de kleuren zwart en grafiet.
Bose AV 321 Subwoofer Not Working.
Bose Service centre says the parts are not available in India hence can’t repair. Buyers of bose are passionate about sound, difficult to just give up.
The Bass Module stopped working after a short circuit but the speakers are working.
Who would be able to fix this?
Is dit een goede vraag?
Score 4
5 opmerkingen
Hi Puneet Rawat
What had you tried?
What issues you are having now?
like able to turn on but no sound?
door
Mine is well soldered but still no sound to the sub woofer except the smaller speakers only. What could be the problem? i have changed the TDA7396 twice now but no joy
door
Hi Puneet,
did you manage to fix this? I’ve got exactly the same problem. I tested all resistors and capacitors up / from TDA7396 and they seem to be fine. I also replaced the TDA7396 as you did with no sucess. I’m really lost.
Felipe
door
scusate il problema e di un chip siglato A3089G
sapete dove posso trovarlo?
door
checco70t: How do you arrive to the conclussion that the problem is with that chip? Also, where is this chip located? it's not displayed in the electrical part list in the service manual
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Puneet Rawat  this could be a Bass module issue on your Bose. Post some good pictures of the modules etc. with your question. That way we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
Here is the schematic for the module and you can start checking components with a multimeter. Let us know what you find.
Afbeelding
Was dit antwoord nuttig?
Score 3
Have you checked the fuse?
From Bose Troubleshooting guide:
”AC mains power is connected by the line cord via jack J1. A slow acting fuse F1 is connected between J1 [D7] and the locking primary connector J3 (or J2 or J4) to protect against faults. A Metal Oxide Varistor (MOV) VR1 is placed after the fuse and across the line. It is used to protect against lightning strikes and other line transients. “
I did some research and it sounds like bad solder joints are common in this unit, So I would look for any cracked joints, cold solder, etc. while you are in there inspecting the fuse.
Score 1
2 opmerkingen:
Mov VR1 do you know wich one can i buy
door
First you should use a meter to confirm that the part(s) is(are) bad. Start by re-flowing the solder to those parts. You can also short the fuse to see if it works, but I wouldn't recommend leaving it that way.. the fuse is there for safety of you and the device.
I found that part on tessco
https://www.tessco.com/product/suppresso...
door
ciao ragazzi io ho il problema uguale non va il sub il difetto e il chip A3089G sulla scheda madre del av3-2-1 potete darmi lo schema oppure sapete che sigla a questo chip? e dove poso reperirlo?
Voeg je antwoord toe
Puneet Rawat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 4,584
