Ga door naar hoofdinhoud
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
20 Vragen Bekijk alle
Charges fast and dies fast
Hey I have a iPod touch 6th gen come in for repair
anyways, this is the third one that came in wasn’t charging or turning on… so I decided to change the battery and re solder a new one in. It’ll charge very quickly and drain fast as well. I’m not sure if it’s the batteries I am getting off eBay or if something hardware is at fault on the logic board causing this issue. Is this a U2 IC Failure? Any shops that have this same problem it would be great if you could chime in with a Solution. It also recognizes with the computer and charges at 0.72 volts
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Try the battery that iFixit sells.
iPod touch (6th and 7th Gen) Battery
iFixit generally has decent quality batteries.
Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V). Afbeelding
Product
$19.99
Was dit antwoord nuttig?
ipods generally have a terrible battery life,
Voeg je antwoord toe
Daniel Ringuette zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 2,498
