Kitchen Plumbing Drainage Configuration
The piping under the kitchen sink seems to be less than effective. I’ve attached photos & would appreciate suggestions on how I can reconfigure. Thanks
Is dit een goede vraag?
@arch It looks like whoever did this wanted only one p-trap but clearly didn’t install it properly. Also since there was no external venting available, they used an internal air admittance valve which is not a problem but it does require you to check it's functionality occasionally as that could also be a culprit (if everything seemed to work well before).
Example of how it works:
Photo provided courtesy of this site
Example of this valve is here: https://www.amazon.ca/gp/product/B0069KD...
Lastly, you know as everyone has told you, that slope is WAY wrong. Here is a sample photo of what it "should" look like:
Was dit antwoord nuttig?
Thanks for the good solutions to the problem! I have exactly the same situation under the sink in the kitchen. However, I'm not sure if I should try to do everything myself or call a specialist?
If you aren't familar with plumbing, have a bad back, little patience, or no tools to perform the repair, then I would recommend you NOT do the work yourself.
Hire a reputable plumber who can give you a quote based on the pictures and can tell you HIS/HER take on what it should be and they should be able to draw it out for you. If it seems reasonable, then hire them (after checking their referrals though). Angie's list (US) and Homestars (Canada) is a great place to start if you have no desire to talk to your family and friends for recommendations.
@Julie Kilcrease if you feel comfortable doing it, go for it. Post some pics if you'd like so we can see and make recommendations on what adjustments might be needed. In the pics OP posted, alot of his problem could be helped by shortening the black pipe from the disposal. This would eliminate the downward slope towards the disposal and help it drain properly.
arch not sure if it is your pictures or your drainage pipes are not sloping the right way. It appears as if your drain goes into the garbage disposal. You’d have to get that fixed for sure. Also, it looks like you are having some vent issues. Hard to see, but can you ty to tell us what the last component next to the wall is It does look like some kind of vent….
Sorry, I didn’t see that there was an actual reply. The drain comes out of the garbage disposal & attaches to the drain from the other sink. They drop into a P trap in the middle & out behind the wall, with a vent near the wall. The drain between the sink & the garbage disposal slopes to the right, which maybe the cause of some the the drainage problem, along with the hose from the dishwasher dropping below the garbage disposal. That’s why I’m wondering whether the pipe between the garbage disposal & the other sink need to be level or is the slope not a problem? Also, do I need to have the tube from the dishwasher stay above where it goes into the garbage disposal or does it not matter? Thanks
You got a lot of slope going back into the garbage disposal etc. anytime your left sink drains it will first run into the garbage disposal etc. You do want to at least get it somewhat level. This appears to be a bit extreme. Your P-trap also looks like it is almost laying sideways. I recognize it's a pain under the sink and really tight with the garbage disposal (had the same issues under my sink:-) but you will have drain issues the way it runs right now.
This is about as optimal as you can get. Everything is draining down. The possible exception is the disposer, the black pipe out of it seems about a 2 cm too long. Remove the connection and hacksaw off a bit and replace the connection.
It looks like the drain setup has extra bends and a long horizontal run, which can slow drainage and cause clogs. A simpler configuration with a proper P-trap directly below the sink, fewer turns, and correct slope toward the wall drain would improve flow and meet code more reliably.
I’d start by correcting the drain geometry before replacing any parts. The black discharge pipe from the disposal appears to be creating an unnecessary low point, which can hold water and debris. Shortening that section should give the drain a cleaner path into the trap.
I’d also check that the P-trap is positioned correctly and that the air admittance valve is opening and closing properly. If the sink previously drained well and gradually became slow, the valve is worth checking before changing the whole arrangement. The trap should also remain accessible for cleaning.
Once the drainage is working properly, the fixture arrangement under the sink will be much easier to keep tidy. I’ve seen the same principle matter when planning kitchen and bathroom layouts, where clearance around plumbing has to be considered alongside the fixture itself. Dupont Kitchen & Bath Fixtures in Toronto also puts attention on proper plumbing clearance when fitting vanities and tops, which is a useful reminder that the visible fixture and the pipework need to work together.
Based on the replies above, I’d first shorten the disposal connection, verify the trap alignment, and test the AAV. If you can post a clear photo showing where the drain enters the wall, it would be easier to suggest the exact configuration.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 39
Altijd: 1,391
3 opmerkingen
@nlkplumbing here is a question that could use a professional. Wanna give it a try to answer without self promotion?
door oldturkey03
I was having the same problem…Can you recommend a good plumber for a low price because now I can’t afford spending much money…thank you
door Jacob Poole
@avalon_star
ifixit discourages recommendations as it can be too subjective.
Search online for plumbers in your location and then check any reviews about them.
If they have websites, search them for information as to how much they charge and if there are any discounts for seniors (if applicable) or such like and also if they charge a call out fee or not
Once you have 2 or 3 that seem suitable, contact them and ask about price and availability to do repair and then go with who you feel would be best.
Maybe your friends may know of someone who they would be happy to recommend
door jayeff
