Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Tecno Y3s Android-smartphone werd in april 2015 door Tecno uitgebracht.
phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
Is dit een goede vraag?
Score 20
2 opmerkingen
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
door
Sir, my mobile battery is very weak, what should I do to get it fixed?
door
Voeg een opmerking toe
7 Antwoorden
Filteren op:
Het nuttigste antwoord
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
Was dit antwoord nuttig?
Score 3
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
Score 3
To take a look on battery terminal if a well connected second to check life of battery
1 Opmerking:
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
door
Phone is not power on and showing logo
1 Opmerking:
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
door
My phone charging socket is not working
No problem my phone is ok
Charging my phone slow way
Voeg je antwoord toe
Eric Matibila zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 28
Altijd: 3,631
