phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
Is dit een goede vraag?
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
Was dit antwoord nuttig?
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
To take a look on battery terminal if a well connected second to check life of battery
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
Phone is not power on and showing logo
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 2,939
1 Opmerking
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
door gharib mahmoud
