2002 Isuzu rodeo it will turn over but won’t start
I replaced the fuel pump on a 2002 Isuzu Rodeo, V6 it started after I primed the fuel rail, the vehicle started up now it will turn over but won’t start, fuses check good, fuel pump comes on and vehicle has spark. Battery is new. What could cause it from cranking all the way over? been told the fuel pressure regulator could went out what do others think.
Is dit een goede vraag?
@texasrebel01 you got me a bit confused. Eiterh it does turn over (crank over) or it does not. If it turns over(cranks over) but does not start then you maybe looking at a fuel issue. We need to make sure that we understand the question before we can five you some decent advice.
Rep: 1
door oldturkey03
Yes it turns over but won't start
door Veronica
How can engine repair
door Dharma hema
Hi @dharmahema ,
Sorry to hear about your Isuzu being broken! We can’t provide you with any repair advice right now though because we don’t know exactly what we’re working with. Please update your post to include the make, exact model, Engine size, symptoms of your problem, and the troubleshooting you’ve already tried.
door oldturkey03
I'm having this problem too! I put a new starter new battery near starter relay, but will not crank over. It only clicks. Does not crank just one click at a time/key turn. Idk what to do or try?
door Alfonso Rodriguez
4 commentaren meer tonen
