Ga door naar hoofdinhoud
Er zijn verschillende series DeLonghi ESAM koffiemachines. De sticker met de typeaanduiding ESAM 3xxx, ESAM 5xxx of ESAM 6xxx bevindt zich meestal aan de onderkant van de machine.
20 Vragen Bekijk alle
Delonghi 6900.m No steam. Weird noise
I have a Delonghi Primadonna Exclusive 6900.M
Everything seems to work fine except for the steam.
It will produce hot water out of the water spout and will also do a full descale.
But when I choose the steam function or put the milk canister on it makes a funny noise like it has a blockage because when I stop it some steam comes out the back of the machine. I have always done the descales and changed O- rings when needed. Greased up the enfuser when was getting stuck, that fixed that. Put rubber grommet in suction straw on the milk canister that has a smaller hole in it to slowdown the milk feed so that it heats up more, got this from delonghi. Hot cuppachino now.
What do you think is the problem. Could it be the solenoid doing this.
Update (06/23/2018)
The machine has a external push on water and steam spout.
This is the machine.
Also a milk jug.
Is dit een goede vraag?
1 Opmerking
Hello,
have you solved the problem? Because I have the problem on the same machine (delonghi esam 6900)everything is working execpt steam…..
thanks
sory for english I’m french….
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If anything that sounds like a properly functioning solenoid.
I made you a schematic:
Maybe there is a blockage in the steam wand; the steam getting released after the function is shut off sounds like it is getting blocked on delivery to the cup.
Its pretty common for there to be milk dried in the steam arm if it's not purged after steaming.
Hope this helps,
Timothy
Was dit antwoord nuttig?
2 opmerkingen:
Look at comment
door
I know the problem but how do I fix it?
door
Voeg je antwoord toe
gbortolli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 5,878
