Toshiba 32" television gone with black screen everything works fine ex
Toshiba 32" television works all good except the screen went black Is it a fuse .
Thank you
Is dit een goede vraag?
Thank you
'''++Patrick OBrien++''' possibly but you will actually have to open it up and take a look. Before you do that, turn the TV to a station where you know it would have a picture. the dim your room and shine a flashlight at an angle against the screen. See if you can make out shapes, silhouettes etc. If so, it is your backlight that has given out. The possibilities with your TV could be a failed power board, failed, t-con board, failed LED driver or a failed backlight array. So, we will need you to let us know the exact model of your TV and once you open the back post plenty of good images of the boards etc. with your question. that way we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 5,662
2 opmerkingen
Led screen letter on
door Shiva Jaat
@Shiva Jaat if you need some help to get things fixed, try to give us more information. What does it mean when you say "Led screen letter on"? The more information you give us the great the chance to fix it.
door oldturkey03
