Ga door naar hoofdinhoud
De Skullcandy Hesh 2 is een set draadloze Bluetooth-over-ear hoofdtelefoons verkocht door Skullcandy. Het model Skullcandy Hesh 2 is te identificeren aan het modelnummer S6HBGY-3xx.
No sound in one speaker
The sound in one of my headphone's speakers is rather faint and sometimes completely absent. I think it might be a internal wiring issue or a faulty speaker. Is there any way I might be able to repair or replace the speaker myself?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@rhatten5 you need to check the wiring to the speaker that is not working properly. Depending on which side, it may be the crossover cable or the wiring right on the speaker. Yes you can replace it but you need to find a replacement which is not always easy. At this point I would check the wiring first. Post some images of what your speakers etc. Look like so we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Check this video to get to your speakers etc.
Use a multimeter and check to see if there is continuity from the plug/board to your speaker. If not then it is the crossover cable. If there is then the issue is with/on the speaker.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
when i connect my hesh 2 headset on aux cable i get sound on both ears, but when i connect on bluetooth i get sound only on the left ear.. what is the issue.. plz help fixit
door
I have the same issue.
door
I also have this same issue with my Skullcandy hesh2
door
I too :/ help please
door
Voeg je antwoord toe
Ryan Hatten zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 27
Altijd: 4,217
