Ga door naar hoofdinhoud
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
Why wont my phone charge?
My charger got wet (gatorade all over it) and i thought that i had dried it before i charged my phone with it. It charged about 20% then it stopped charging, and now my phone wont charge at all, with any charger. What do I do???
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Chances are your wet charger has damaged your phone's battery. If that is the case then you need a new battery. The only other solution would be to use direct power while you use your phone, meaning that you will have to be at home or some building to use your phone while it's plugged in.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jada J zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 91
