Ga door naar hoofdinhoud
Model A1288 / 8, 16, or 32 GB capacity
451 Vragen Bekijk alle
My ipod is locked and I forgot the password
I need help unlocking my ipod touch
Is dit een goede vraag?
Score 50
1 Opmerking
Sankaraperugu
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
If you connect it to the same computer it is "paired" to for syncs, you can force the pass code off:
  1. Connect your iPod Touch to iTunes
  2. Press or Hold the power and home keys 10 seconds.
  3. Screen goes black, now release the power button
  4. Make sure you do not release the Home key until your iTunes says "We have detected an iPod Touch in recovery mode."
  5. Restore the iPod
You will, of course lose any content which has not synced back to itunes from the iPod...
See also Apple's tech note on this.
Was dit antwoord nuttig?
Score 27
13 opmerkingen:
David Iwanicki's fix also works if your Ipod is stuck in a loop it is step 4 that saved my ipod 32 gig
now i got one more to fix
door
Works 100%, thanks
door
thanks alot great
door
Thank you so much, I goggle on how to unlock iPod touch this was best answer by far, I looked like a pro to my son and became the hero :) thank you again.
door
it is not dislaing the passkey part it says that i connect to itune
door
8 commentaren meer tonen
You may get the solution from here: https://discussions.apple.com/thread/490...
Score 2
try putting wrong password first then hold the lower left button for 5 seconds, then press 3 and hold the lower left button for 2 seconds and repeat... and afterwords when it says wrong password press cancel a message will come up and it will tell you your password is — — — —. (ONLY WORKS FOR IPOD 3G,4g AND IPHONE 4 NO IPOD C OR Cs OR IPHONE 5,5s,6 or 6s
1 Opmerking:
what button??
door
Restore/ renew from iTunes
It’s not rocket science
1 Opmerking:
Except iTunes is a nightmare to navigate 98% of the time
door
Voeg je antwoord toe
shad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 80
Altijd: 148,220
