Ga door naar hoofdinhoud
Announced in October 1999.
20 Vragen Bekijk alle
G3 Will not power-up after power failure.
Nothing happens when I push start button on front of machine. Power source and connection is good.
Is dit een goede vraag?
1 Opmerking:
Unplug the machine, open it up, and remove the PRAM battery. Wait awhile (min 15 mins; I'd leave it that way for longer). Test the PRAM battery to make sure it's still good, or just replace it if you aren't sure since it's cheap enough.
While you're there, check the power supply for swelling caps and replace as necessary.
Put it all back together and try to power it up.
door
Voeg een opmerking toe
1 Antwoord
Did you check the breakers?
Was dit antwoord nuttig?
Voeg je antwoord toe
Barnett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 147
