Ga door naar hoofdinhoud
iFixit gebruikt cookies om de functionaliteit van de site te verbeteren, het verkeer te analyseren en advertenties te personaliseren. Door onze site te gebruiken, gaat u akkoord met ons cookiegebruik en privacybeleid.
The second generation Rogue is a version of Nissan X-Trail and inspired by the Hi-Cross Concept to adapt to North American market.
10 Vragen Bekijk alle
Radio buttons on steering wheel not working
Radio buttons on steering wheel that allow you to change from one station to another work when car is simply turned on (engine not running), but don't work when engine is turned on. (Can't change from one preset station to another). Volume control works both ways and all other functions work just fine (touch screen, control knobs) in both situations. 2016 Nissan Rogue
Is dit een goede vraag?
Score 1
7 opmerkingen
Have you ever been able to change the station presets while engine is on? If not, then this is likely a factory option. If so, then it is possible that your steering switch is broken. You could try scanning for codes, just incase.
door
Yes, we could change the stations from the steering wheel. And the volume controls on the steering wheel still work. In fact only this one feature has stopped working. Called Nissan and will be taking the car in for repair. They had no other suggestions.
Thanks for your input.
door
Every time I turn left that shuts off my radio and my DVD what could this be
door
Dudden Jim - I would say this mostly likely a short in the wiring harness between your steering wheel and the head unit. I would check on crutchfield.com in the FAQ I believe they have a solution for this problem.
door
Dudden Jim - sounds like the clockspring behind the steering wheel could be bad. Any repair shop should be able to test and replace if necessary.
door
2 commentaren meer tonen
Voeg een opmerking toe
7 Antwoorden
Gekozen oplossing
Check to see what is displaying in the center display on the dashboard between the tach and speedometer. The channel buttons will not work if you are displaying the settings page. Try changing it to MPG display.
Was dit antwoord nuttig?
Score 4
7 opmerkingen:
Tom, you are amazing and right on. No one at Nissan could figure this out. Thanks so much.
door
Yup, have 16 rogue couldn't figure it out, was frustrating new car only 26,000 miles and stuffs not working?? So googled finally came upon this genius and was correct!!!! Even in park would not change if I was on warning page, then changed to mpg and worked immediately!!! Bravo bravo!! Thank you
door
I just bought a used 16 Rogue and am having the same problem - but can’t quite understand how to implement this solution? How do you make it display MPG? When I turn on the ignition, it seems to just display “no warnings”, outside temp, milage, etc.
door
You're a genius. This worked
door
Wow!!! Thanks!!
door
That’s crazy but it worked on my 2016 Rogue! Thank you!
Score 1
2 opmerkingen:
Thanx... My 2018 Nissan Sentra SV had the same problem. Very Helpful.
door
USB Flash Drive and Change Songs same thing. Changed Screen. Now it works.
door
Shouldn't this be a recall item since it appear all Nissans eventually have this issue
Score 1
My sourge bottom is not working on my 2012 altima .is it a fuse or something else ? Radio is working fine but not from steering wheel !! Thank you .
1 Opmerking:
On my 2014 Altima SL the volume will only go all the way up or all the way down and this happens in its own. It wouldn't work at all for a while . Also i can change the settings on my screen it only shows the nav can get the radio the show or my satellite radio nothing
door
Thanks everyone! I just had my car serviced yesterday and was having this issue this morning. Fixed.
1 Opmerking:
2014 Nissan rouge steering wheel audio control do not work in 2014 Nissan Rouge
door
Omg! This is amazing! That’s all it took! Genius.
To the person that went to the Nissan dealership for service what did they do to fix it? I have a 2015 Nissan Rogue. The left side of my steering wheel Has my radio/phone controls. I noticed this morning neither are working. I did try putting my screen on MPG which is where it is now and that did not fix it. I just thought maybe since You said you took your car in for a repair and I thought maybe they told you what was wrong with it and you would share. Thanks!
1 Opmerking:
I have same problem with my 2015 rogue
door
Voeg je antwoord toe
Bill Luftig zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 55
Altijd: 105,505
