Ga door naar hoofdinhoud
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Screen dims then turns off after certain angle
Hi, my 12" Macbook (2015) has developed a problem where the screen turns off after opening beyond a certain angle (at the moment about 60 degrees). It works normally if I only open the screen slightly or with an external display, but when attempting to open the screen beyond a certain point it starts to dim then completely turns off.
When it turns off the laptop still works with an external display and sound still plays - just no image at all on the monitor. Closing the laptop to put it to sleep then reopening gets the screen to turn back on.
Any ideas what might be the problem or if this is fixable?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
This definitely sounds like the display cable is being pinched by the case. I would recommend keeping the laptop closed until you are ready to fix the issue, as if the cable keeps getting pinched it can rip or tear.
This is fixable, you just have to use the iFixit guides to get to the Display cable, and then adjust it so that it is no longer being pinched.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Liam Newton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 668
