Ga door naar hoofdinhoud
De Xterra werd in Noord-Amerika geïntroduceerd in het modeljaar 2000 (kalenderjaar 1999) en op de markt gebracht met de slogan Everything you need, nothing you don't.
Temperature gauge not working and no check engine light!
I have a 2000 xterra 4wd, my temperature gauge isn't working but my check engine light has not came on. when i turn it on it stays below the cold line, it doesnt move even after 20 min of it on. its not overheating or anything, all of my other gauges are working what could it be?
Is dit een goede vraag?
Score 1
1 Opmerking
My temperature gauge and my gas gauge has stop working as of Thursday.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Three things. Sensor Wiring or Gauge.
Start with the easiest
Test wires
Then test Gauge
Then replace sensor.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks I’ll try this out tomorrow!
door
This is ridiculous. Is there no one out there that knows the difference between a sending unit and a sensor? Freaking Google bone headed responses. GAHH! The coolant sensor has nothing to do with the temperature gauge in your dash and its title is misleading - it is solely for your car's computer to make adjustments. It is the coolant temperature sending unit that moves the gauge in your dash. I had this same issue in my vehicle and your symptoms sound classic for a sending unit replacement. Although, I might be asking myself what caused it to go bad if I were you. I bought my vehicle this way, and I am convinced mine went bad from an overheating. Luckily, my motor is a 7.5L 460 Ford V8 - a beast that keeps on turning. Don't get me started on the rest of the vehicle though. >:-O grr... Good luck.
door
Check the thermostat
Voeg je antwoord toe
Brian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 26
Altijd: 7,726
