Ga door naar hoofdinhoud
7,9-inch scherm / Model A1454 / Beschikbaar in zwart of wit / Aangekondigd op 23 oktober 2012 / 16, 32 of 64 GB opslagcapaciteit
Digitizer Plug on Logic Board
Hi Guys,
I have an Apple iPad Mini 1st Gen Model# A1432 here which needed the Digitizer replaced. The plug that the Ribbon Cable clips into on the Logic Board is missing some of the Gold Pins and as a result the Digitizer isn't working. I am not sure what this item is actually called. I was just wanting to know if anyone could help with the of that part and or if it is available to purchase. I will also need to Purchase a new LCD Screen at the same time as when I turned it on it's coming up with 2 apple logo's and lines across the screen. Any help would be greatly appreciated. See picture attached the part I need is circled. Thank you in advance.
Afbeelding
Regards,
George McMahon.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You can buy those but you need someone proficient in micro soldering and previous experience of doing those really to attach it correctly.
Was dit antwoord nuttig?
2 opmerkingen:
*cough cough* @refectio *cough cough*
door
Thank you so much for your help. I really appreciate it. I will definitely have to look for someone who is proficient in Micro Soldering as I am not. Thanks again,
Regards,
George McMahon.
door
Het nuttigste antwoord
@gm78 the connector is a Molex 503304-2010 . It is available at places like this and many others. To repair it you will need to know how to microsolder (and of course have the tools) or get someone like @refectio to repair it for you.
Score 1
3 opmerkingen:
@oldturkey03 where do you find this stuff out? so much random knowledge! =)
door
@captainsnowball it's all random from fixing random things ;)
door
Thank you so much I really appreciate your help. I definitely am not proficient enough in micro soldering so will have to get it done by an expert. I am in Adelaide. South Australia. I will have a hunt around to see if I can find someone here that can do it if not I will look into @refectio to do it for me. I really appreciate your help. Thanks Again.
Regards,
George McMahon.
door
Voeg je antwoord toe
George McMahon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 662
