On off button sticking and stiff
My on off button seems hard to move and sticks in postioymoved to it used to just spring back by itself
Is dit een goede vraag?
Krijg snel toegang tot handleidingen, onderdelen en antwoorden voor jouw apparaten
Sounds like a button that is physically stuck, like you said, get a bottle of Isopropyl Alcohol and a Q-Tip, dip the Q-Tip in the bottle, gently swap the switch with the wet end of the Q-Tip (make sure the device is off) switch back an forth. Rinse and repeat until the switch is loose again. Hope that helped!
Was dit antwoord nuttig?
Where can I purchase a new button. My button came completely off?
constant problem with these cameras. even lubrication does not help
I put new batteries in the camera and won't come on
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 2,503
1 Opmerking
Tried it made slight difference button still not working properly one of the kids must of dropped it as it still doesn’t move back itself as it use too but thanks for your suggestion will probably have to take it to a repair shops
door gazza b
