Ga door naar hoofdinhoud
Identified by model number G6U46UA.
2 Vragen Bekijk alle
Touchpad Pointer prematurely executes when it "hoovers" over something
When using the touchpad, and moving the pointer around, if it moves across an executable item, even "hovering" over it for a split second, it executes that command before you "click" on the touchpad left button as you would expect to do.
This is horrible, and I can't imagine that this is the way it's intended to work. Is this something that can be fixed with a setting change, driver change, or otherwise?
Is dit een goede vraag?
1 Opmerking
What Operating system are you using?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Looks like I've found a "fix"; in "settings", touchpad, turn off the "finger tapping" option -- this seems to have worked ok.
Was dit antwoord nuttig?
Voeg je antwoord toe
Byrne Whitehead zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 98
