Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
2ds Camera Replacement help?
Recently had a juice bottle explode in my backpack, and of course it got all over the 2ds in there.
I let the system dry out, had severe issues with the circle pad and other buttons sticking, so I cracked it open to clean everything out with alcohol wipes. I tore the camera cable during this, unfortunately.
I finally have a replacement piece, and I've got it installed, but the camera is still not working. I've popped the cable in gold side up and gold side down, made sure it was fully seated in the socket, and still no change.
Had I the money, I'd simply send it off to Nintendo, but being completely unable to work means no income, so I'm hoping someone here can tell me what I'm doing wrong.
I also have had an issue with the charge indicator light being on constantly since the juice incident, I'm not sure if that's related. I'm fairly certain it's just the circuit for the light that's borked, the unit still charges and plays normally, aside from the camera issue.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
liquid damage doesnt just physically damage components. it shorts out the board as it dries up. So what you would likely need to do is a standard water damage repair.
Water Itself is not damaging to the board. water in it's purest form is non-conductive. the actual problem is the minerals in the water. (Iron, Calcium, Sodium, Lime) These are conductive and cause damage. unfortunately, they have a much higher boiling temperature than water, so when the water evaporates, (Sped up by the rice) these minerals are left on the motherboard. Rice doesnt actually help the damage, but rather speeds up the drying porcess. If the phone functions WITH the rice treatment, it would have worked without the rice treatment.
as a water damage repair, it still is only 50/50 as to whether or not you can get the device up and running. follow the next steps, andyou may have a functional device.
1) Isopropyl: Take a 99% rubbing alcohal, also known as Isopropyl, and a toothbrush. (New, as it can not be previously contaminated by conductive materials such as saliva, or tap water) soak the board in the isopropyl, and scrub diligently. make sure not to be terribly rough on the board, but still use a heavy handr
Check to see if board works
2) DeOxit (Electronics cleaner): I have used many brands, but DeOxit is the the one i have had the most success for, so i suggest this brand. others may work, and it is only a personal preference. spray the cleaner onto the board, and seal in a tupperware container. let sit for an hour, then re-soak with isopropyl to dilute any lifted dirts, and scrub with the tooth brush. Essentially, after the DeOxit has sat, Repeat step one.
3) Sonic Wash: This is implying you have access to the tool required. usually need a repair shop environment to have one The sonic wash is a tool, usually cosing between 300$-500$. fill it with distilled water and a liquid electronics cleaning solution. this pulses the cleaner underneath components where a brush can not reach. though this is the most successful procedure, it is also the most expensive of the three.
i hope this helps, and if it does, please accept the answer.
4) After all of these procedures, if any funtions aren't working, try replacing the modular component that the function is related to. (Antenna's for signal, Charge port for charging, Camera for camera function, ETC.)
Anything further than this will be a board level failure.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
So this would require a complete disassembly? Not entirely sure if that's within mine or my father's skill range. I'll consult with him about it, but I may end up just limping on without camera function. We accidentally killed my DSlite when we cracked it open to replace the touchscreen. Touchscreen worked fine, but the unit refused to charge afterwards.
So i'm a little leery of the possibility of killing the 2DS. Might just have to get physical copies of my games so i can borrow the brother's 3DS when I need the camera.
I really appreciate you taking the time to answer my question, though.
door
Try to get a toothbrush and some rubbing alcohol and dip the toothbrush in the rubbing alcohol, then clean the conector and sorounding area, this may not work but if you havent tried this, then definently do it.
Voeg je antwoord toe
Jennifer Lincoln zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 42
Altijd: 1,179
