Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
409 Vragen Bekijk alle
How do I fix my broken xbox one S sync button?
Okay so i figured out around two days ago i tried syncing my controller to me xbox one S but it wouldnt work i pressed the sync button on my xbox and i couldnt hear a click sound it makes normally when you sync a controller is a peice missing or is my sync button broken?
Is dit een goede vraag?
Score 7
Voeg een opmerking toe
14 Antwoorden
Het nuttigste antwoord
Plug Controller in USB.
2. Hold Power Button for 10 seconds.
3. Unplug the Power Cord for 10 seconds.
4. Plug Power Cord back in to Xbox.
5. Power On Xbox Press Power Button on Console.
6. Soft Power down Xbox Press Button once.
7. Disconnect USB from Xbox and Controller.
8. Power on Xbox with Controller.
You're Welcome. Enjoy!
I found this on a different page and it worked!!!!
Was dit antwoord nuttig?
Score 13
19 opmerkingen:
Didn’t work At all
door
It worked for me
door
It works! Thank you sooooo much
door
dude instructions are so unclear that its not even funny
door
This didn’t work at all dude actually post something helpful
door
14 commentaren meer tonen
With mine all I had to do was take the disk out and boom problem solved so make sure there's no disk in when ur trying to sync.
Score 2
2 opmerkingen:
Same I was really suprised
door
thank you sm for this you fixed my issue
door
How to fix the problem and it’s broke
Score 1
1 Opmerking:
Use a pencil, when it broke off when I touched it with my finger, I used a pencil and it worked
door
You can get a new one but you can also sync your controllers by using the USB port in the back of the Xbox One mine is broken as well so I just use the USB port to sync my controllers to the Xbox
2 opmerkingen:
okay thanks for letting me know but how do i sync my controllers to my USB by the way im jack nutter who asked the question i just had to switch my profile though
door
How do I do this?!
door
I know this space is for an answer but I'm having major problems with the sync I press it and it clicks but it doesn't flash plz help
3 opmerkingen:
Mine does that aswell and it’s annoying as because I can’t play Xbox now
door
Me too, someone help!!!
door
connect a usb cable to the controller and the usb port on your xbox. Try all of them, as on my Xbox One there is one that doesn't work
door
Other answers worked finally. Annoying product
yes but is broken and this is not working
There's 2 Sync Buttons, one to the left of the power button, and one below the power button on the black base, the second one is the one you have to press in order to pair any device you have.
1 Opmerking:
Where is this second sync button and how do I use it?
door
I took mine apart and found the actual bind button itself had fallen away from the board. I haven’t mustered up the courage yet to attempt to solder it back on, but I have a feeling that is the only way to fix it.
There should be a USB plug in on the back of the Xbox. So grab the charger you use for the controller and plug it into the back and plug it into your controller. It worked for my brother.
Hard reset the Xbox, no data will be lost other than cache, it might work after.
When my sync button quit working I replaced the rf module. Only cost me like 30 dollars for that and the tools
idk if this will work for you guys but I moved everything in front of my xbox and made sure nothing blocked the pairing sensor and put my controller super close to the sensor and it worked
Address:
Peer Shaheb Lane, Dhaka 1217
Phone:
01798-777803
Website:
https://nashidbashar.com/seo-expert-in-b...
GMB:
https://g.page/nashidbashar
Nashid Bashar is a Clickminded certified SEO expert in Bangladesh. He is serving as an SEO consultant in California-based Company ProAir Industries, Inc.
Voeg je antwoord toe
Jack Nutter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 240
Altijd: 47,248
