Ga door naar hoofdinhoud
Reparatie-informatie en handleidingen voor de iPhone 6 die op 19 september 2014 werd uitgebracht. Modelnummers: A1549, A1586 en A1589
How to Remove iPhone passcode lock without updating iOS version
I have an iPhone 6 on iOS 9 that I forgot the passcode to. The phone is not stolen, it is clean IMEI and it has no iCloud lock. The phone is not logged into iCloud so I cannot wipe it like that. I've had this phone since it came out and I lost it a while back and I just recently found it. I just need some help if anyone knows how to get rid of the passcode lock without updating to the latest iOS version because I want to keep it on iOS 9. I don't mind losing everything on it, just if I can get access to the phone without updating to latest iOS version. Please, any help would be great.
The main goal is to restore and/or remove the passcode lock without updating.
Is dit een goede vraag?
Score 5
1 Opmerking
There are only ways to remove passcode from iPhone device. You can reset your passcode when synchronized with iTunes but this method will erase everything and settings on your device and should be used cautiously.
another ways is try iPhone screen locker program to remove passcode without losing data.
Source:
https://www.iseepassword.com/forgot-ipho...
door
Voeg een opmerking toe
10 Antwoorden
Gekozen oplossing
I've not tried the following, but see if you can create a backup to Itunes (Create an account if you don't have one). Then follow these steps and let me know if you try and it works or what solution you have done to accomplish what you are trying to do.
https://support.apple.com/en-us/HT203434
Was dit antwoord nuttig?
Score 6
3 opmerkingen:
I cannot create an itunes backup because when the phone is plugged into itunes, it tells me to enter the password for the phone so i can access it, but i do not remember the password. I appreciate the help though!
door
Hey I do not know what my password is on my iPhone 6 can you all help me please
door
Maybe this will help
door
Here's how Apple says to do it:
https://support.apple.com/en-us/HT204306
Score 5
3 opmerkingen:
This will restore and update the phone. I do not want to update the phone. But thanks for the reply!
door
You have to be able to read and follow the directions:
"When you see the option to Restore or Update, choose Restore."
door
it does not give me that option. it tells me to restore and update together. i appreciate the help though
door
The old iOS link is here:
http://www.iclarified.com/750/where-to-d...
On a PC you hold Shift and click restore to select the iOS file you downloaded from here.
On a Mac you hold Option.
However, you may not be able to accomplish this. iOS 9 signing servers have been shut down long ago. Unless you saved SHSH blobs using Tiny Umbrella https://tinyumbrella.org/, you may be out of luck.
Score 3
As far as I know, there are only two options to remove a forgotten iPhone passcode when you’ve locked out: Erase iPhone and Restore iPhone. If you don’t have an iCloud account used on the iPhone, you can’t remove forgotten iPhone passcode without doing a restore. In the process of restoring, your iOS must be updated to the latest version.
Score 2
it was so helpful because i unlock the pass
Score 1
1 Opmerking:
How did you pass it can you please let me know thanks
door
As you can’t bypass passcode with iTunes and iCloud, maybe you can try a iOS passcode remover like Joyoshare iPasscode Unlocker. It can fix your problem and other issues like unlock Face ID, and Touch ID, and it’s quickly and safely.
Score 1
Great Article, It was Very Helpful For Me. Here is a Detailed Post on Fix black facetime logo on iPhone
Score 1
My experience tells me that iPhone passcode can be removed by iTunes, iCloud or 3rd-party tools such as FoneGeek iPhone Passcode Unlocker.
Score 1
1 Opmerking:
How do iPhone 6 password remove
door
How do iPhone 6 passcode remove
1 Opmerking:
How to iphone passcode remove
door
Voeg je antwoord toe
hussein hachem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 85
Altijd: 22,821
